edmundwatson
Sep 08, 2012Aspirant
Largest Drive addable to Duo V2
What is the largest drive that can be installed to a Duo V2? and out of curiosity what is limiting it to that size? Thanks,
Sep 08, 2012Guru - Experienced User
The largest drive on the HCL is 3 TB (http://www.readynas.com/?page_id=82).
edmundwatson wrote: What is the largest drive that can be installed to a Duo V2?
Thanks,
A 4 TB drive could probably be installed and work. Though there's a risk that the drive might not be compatible, and Netgear will generally deny support if the drives are not on the HCL.
