Yeager88's avatar
Yeager88
LCD Display Dead - ReadyNAS Pro Business
Hi Folks,
Has anyone else had a problem with the OELD Display malfunctioning on the ReadyNAS Pro Business Edition (RNDP6310)? Could this be an incompatibility with the latest firmware? Does anyone know where I can find older versions of the firmware to try? Many thanks in advance for any assistance you can provide. :-)
-Y
1 Reply
  • Is it still under warranty?
    Are you running 4.2.27?
    I have not heard of this problem on the forums.
    What exactly is happening? Nothing on the display at all, that sounds like a hardware problem.
    You could , just to be sure, power down, remove all your disks ( label them) insert a spare disk and factory default the unit. if the problem persists then it's almost certainly hardware.
    4.2.26 is at the link below, but it's unlikely to make a difference, if you are planning to install that then I'd do an OS reinstall first, ( assuming you are running 4.2.27)
    http://kb.netgear.com/app/answers/detai ... /related/1
ProSupport for Business
