prime00
Aug 04, 2010Follower
LCD on NV+ shows volume not hostname.
Hi! Maybe this issue has been condsidered in another thread but I don't find it. In the LCD-display I can see the correct IP-address and volume size, but not the host name. Is there any setti...
chirpa
Aug 04, 2010Luminary
The LCD will only show the IP, not hostname.
If FrontView/RAIDar shows Disk 2 healthy, it might be the LED board in the chassis having problems itself. You can contact technical support (numbers below) to inquire about a chassis RMA if needed.
