janpeter1
Jun 27, 2015Luminary
Likely Readynas 3-series
Hello, I plan to upgrade from my ReadyNAS Duo that served me well for 5+ years running 2x2TB in Raid 1. Consider to buy 2- or 4-bay (or even 6-bay hope not) NAS and it is for home use with small o...
- Aug 04, 2015
You could put a suggestion in the Feature Request & Feedback subforum.
You could also make a request at rnxtras.com (not a netgear site)
mdgm-ntgr
Jul 03, 2015NETGEAR Employee Retired
2) I wouldn't use iSCSI for this
3) The 300 series lacks VT-x, so it won't run 64-bit VMs. The 516 has VT-x.
