janpeter1
Jun 27, 2015Luminary
Likely Readynas 3-series
Hello, I plan to upgrade from my ReadyNAS Duo that served me well for 5+ years running 2x2TB in Raid 1. Consider to buy 2- or 4-bay (or even 6-bay hope not) NAS and it is for home use with small o...
- Aug 04, 2015
You could put a suggestion in the Feature Request & Feedback subforum.
You could also make a request at rnxtras.com (not a netgear site)
Jul 04, 2015Guru - Experienced User
Me either. Though truthfully I don't use iSCSI at all.
mdgm wrote: 2) I wouldn't use iSCSI for this
Keeping your media in ordinary shares gives you more options. For instance you can also play your media directly from the NAS from another PC or media player (iSCSI is designed for only one client at a time). You can even run plex on both the NAS and the Mac Mini (sharing the same media library).
