janpeter1
Jun 27, 2015Luminary
Likely Readynas 3-series
Hello, I plan to upgrade from my ReadyNAS Duo that served me well for 5+ years running 2x2TB in Raid 1. Consider to buy 2- or 4-bay (or even 6-bay hope not) NAS and it is for home use with small o...
- Aug 04, 2015
You could put a suggestion in the Feature Request & Feedback subforum.
You could also make a request at rnxtras.com (not a netgear site)
mdgm-ntgr
Jul 06, 2015NETGEAR Employee Retired
janpeter wrote:
I work in the life science sector and people working with databases for genetic material etc
are usually very keen to ensure ECC memory and often use ZFS systems.
Our ReadyDATA devices use both ECC memory and ZFS. However you can't run Plex Media Server on a ReadyDATA. I think a ReadyDATA would probably be overkill for your media collection.
The ReadyNAS 516 and 716X both have ECC memory. It is nice to have.
janpeter wrote:
3) Virtual box - so 32-bit VMs would work I understand your comment as.
Yes, however with just 2GB RAM in the 300 series system you are going to be quite limited in what you can run.
