janpeter1
Jun 27, 2015Luminary
Likely Readynas 3-series
Hello, I plan to upgrade from my ReadyNAS Duo that served me well for 5+ years running 2x2TB in Raid 1. Consider to buy 2- or 4-bay (or even 6-bay hope not) NAS and it is for home use with small o...
- Aug 04, 2015
You could put a suggestion in the Feature Request & Feedback subforum.
You could also make a request at rnxtras.com (not a netgear site)
janpeter1
Aug 03, 2015Luminary
I understand that there are two backup process to ensure:
a) from Mac/PC to NAS
b) from NAS to external HD
However in case of photos I take them directly to the NAS and they never enter my desktop.
Could be other stuff that lands first in the NAS too. So I focused my concern on step b) above.
For some Mac/PC software they likely can check the checksums for two external disks like NAS and external HD,
while many need at least one of the HD to be intetnal to the Mac/PC.
How do I proceed to suggest some add-on to the NAS that do the job b) outlined?
Aug 04, 2015Guru - Experienced User
