SebDes
Feb 16, 2012Aspirant
Mac OS LION nor supported?
I bought a ReadyNas NV+ in September last. Late October I upgraded my computers to MAC OS Lion Except via FTP, I haven't been able to login directly to my ReadyNas ever since. The lady I sp...
mdgm-ntgr
Feb 23, 2012NETGEAR Employee Retired
Cool. Future firmware updates will work the same way. You can configure the ReadyNAS to automatically check for firmware updates. Go to System > Update > Settings and check "Automatically Check for Updates" and click Apply. Also, test email alerts and make sure they're working. I recommend using Gmail: Using Gmail with the ReadyNAS
Then you should be alerted when a new firmware update is available and prompted to update.
Feel free to ask if you have any more questions.
