Zero1
Dec 06, 2017Aspirant
Max HDD support readynas
Hi all, Just want to state first that the model I have isn't with 500GB Desktop drives it actually came with 4x1TB enterprise drives. Now that is out of the way, I wanted to know how can I find o...
Zero1
Dec 07, 2017Aspirant
Thanks for getting back to me.
Yes the NAS is currently on 4.2.19 if im not mistaken and I will update the firmware to the latest it supports. Originally I had the 4TB in the NAS and I already upgraded to a total of 8TB.
If I upgrade to 4x4TB will I have to wipe the data (factory reset) in order to actually get a 12TB of usuable storage? That i can't afford to do and have no means of offsetting the data to accomplish this.
Dec 07, 2017Guru - Experienced User
If you mean you started with a 4 TB volume size ("usable storage") then you can grow to 4x4TB.
If you mean that you started with 4x1TB (3 TB volume size), then the expansion will fail (it's about 200 GB over the 8 TiB growth limit). From a 4x1TB XRAID starting point you can go to 3x4TB+3TB (11 TB volume size).
You have an 6 TB volume size now, correct? Two 4TB USB drives would cost you about $240 USD. I recommend getting those two drives now, and slowing down the expansion.
For instance, 4x4TB would cost you about 680 USB (for 4 TB WD gold disks). Get two 4 TB gold disks and the two 4TB USB drives in the first phase instead (costing $580). That gives you a backup capability and a volume size of 8 TB now. With a backup, you can do the factory reset now with 2x4TB+2x2TB in place, and that will let you expand the volume to the max 16 TB in the future.
RAID isn't enough to keep your data safe, especially if you are upgrading or replacing disks in the array.
- Zero1Dec 07, 2017Aspirant
I agree that RAID isn't anywhere near enough but for now its a temp solution until a new unit is purchased which most likely isn't until next year.
We have already reached the conclusion of buying 4x4TB which would cost about $1000 CAD but I may just have to make it 5 to have a spare and off set the data temporarily to do the factory reset.
We were looking at WD RED 7200RPM Drives instead of the gold.
- StephenBDec 07, 2017Guru - Experienced User
I think you mean Red Pro. There are no 7200 rpm drives in the WD Red line.
The prices I see for the 4 TB Red Pro (WD4002FFWX) and the 4 TB gold (WD4002FYYZ) are the same - within 2 USD on Amazon on the moment. The specs are also nearly identical. Either drive should perform well.
That would do it too - backing up to two of the 5 drives, and then doing a factory install with 3x4TB in place. You'll be able to restore to the resulting 8 TB data volume, and then add the 4th drive to get to 12 TB.
It is also nice to have a spare disk on hand.
Yea red pro - thats what i meant. Way to many damn variations now compared to the older days smh.
U said install 3x4TB first? I set up the NAS to be under netgears version of the raid w/e its called. Doesn't that version need a minimum of 4 drives?
