ScottChapman
Jan 03, 2014Apprentice
Max Memory in 316?
Anyone have any idea how much memory you can put in a 316? I have heard someone is running with a 4GB, any idea if an 8GB card would work?
mdgm-ntgr
Feb 08, 2015NETGEAR Employee Retired
The 516 can take up to 16GB RAM (2 x 8GB). Another advantage of the 516 is that it uses ECC RAM.
With the 300 series you have a single memory slot and are limited to 4GB.
Note we don't support RAM upgrades. Be sure to run at least a few passes of the memory test before trusting the memory. Note that even if it passes it might not be compatible.
