Yionel
Oct 11, 2013Aspirant
Maximum capacity storage per disk with readynas nv+
Hello, I'm sorry, I am newb in NAS system. I have retrieve a Ready Nas Nv+ (back sticker RND4475) I would know if maximum capacity storage disk was dependent of the firmware or of the NAS system ?...
mdgm-ntgr
Oct 11, 2013NETGEAR Employee Retired
The limit is 2TB disks for your NV+ (v1 - silver chassis). Please choose disks from the compatibility list.
You do need to be running somewhat recent firmware to use 2TB disks and for optimal performance it would be advisable to update the firmware then backup your data, do a factory default, then restore your data from backup.
SidCastro
Oct 08, 2015Aspirant
so you mean 2TB disk in each bay? ie: 8TB total capacity for readynas nv+ (silver chassis)?
- StephenBOct 08, 2015Guru - Experienced User
Yes.
That works out to a 6 TB XRAID or RAID-5 volume (~5.4 TiB).
To use the full raw capacity you'd need either jbod or spanning raid-0. jbod is much safer.
- Kaasie17Oct 18, 2015Aspirant
sorry I have to ask a question, you can create RAID 0 even one share with full capacity,therefore a share of the full 8 TB? Thank you for your help!
- StephenBOct 18, 2015Guru - Experienced User
You can create a RAID-0 8 TB volume.
But it is not a very good idea. If any disk fails, the whole array is lost.
- Sep 02, 2016Retired_Member
