Yionel
Oct 11, 2013Aspirant
Maximum capacity storage per disk with readynas nv+
Hello, I'm sorry, I am newb in NAS system. I have retrieve a Ready Nas Nv+ (back sticker RND4475) I would know if maximum capacity storage disk was dependent of the firmware or of the NAS system ?...
SidCastro
Oct 08, 2015Aspirant
so you mean 2TB disk in each bay? ie: 8TB total capacity for readynas nv+ (silver chassis)?
Oct 08, 2015Guru - Experienced User
Yes.
That works out to a 6 TB XRAID or RAID-5 volume (~5.4 TiB).
To use the full raw capacity you'd need either jbod or spanning raid-0. jbod is much safer.
- Kaasie17Oct 18, 2015Aspirant
sorry I have to ask a question, you can create RAID 0 even one share with full capacity,therefore a share of the full 8 TB? Thank you for your help!
- StephenBOct 18, 2015Guru - Experienced User
You can create a RAID-0 8 TB volume.
But it is not a very good idea. If any disk fails, the whole array is lost.
- Kaasie17Oct 19, 2015Aspirant
Problem solved, done theme
- Sep 02, 2016Retired_Member
