srinet
May 06, 2018Aspirant
Maximum Drive capacity
Hi, I am using RN2120 with 4x3TB drives. I want to upgrade it with higher capacity drives. Currently it is running on ReadyNas ver 6.9.3.
1) I want to know the maximum size of hard disk size it...
- May 07, 2018
Hi srinet
Welcome to the Community!
Checking the HCL, suggested drives are at a max capacity of 12TB so you can use 4x12TB for your RN2120. 12TB is currently the largest capacity available for a hard drive.
If you have installed RAIDar or if you login to your RN2120 Admin page it should show RN2120v2 as label for the model. RN2120v2 has an updated processor than the v1 but they have the same compatible disks available. You can also check the product label it should show RN2120-200.
Hope this helps!
Regards
Marc_V
May 07, 2018NETGEAR Employee Retired
Hi srinet
Hope this helps!
Regards
srinet
May 07, 2018Aspirant
Thanks a lot for the quick and candid reply.
- mdgm-ntgrMay 07, 2018NETGEAR Employee Retired
Your RN2120 (4-bay rackmount NAS running ReadyNAS OS 6 e.g. 6.9.3) should not be confused with the RND2120 (which was a 2-bay desktop ReadyNAS, the ReadyNAS Duo with 1x2TB disk pre-installed at the factory) which is a very different NAS model running legacy RAIDiator firmware.
In the case of the Duo there's a much bigger difference between its v1 and v2.
- Sep 02, 2016Retired_Member
