ataman's avatar
ataman
Maximum Harddisk Capacity
Hey Everybody
I am planning to buy a Readynas Ultra 2.
I have a question regarding to the maximum harddisk capacity.
In some online documentation I have read that maximum harddisk capacity is 4TB.
But I also saw a youtube review:
http://youtu.be/t7ps8agfTF4
in which the user installed 2 3TB disk and used them in Raid 1 mode.
I am a bit confused.
What does this 4TB maximum capacity limit that I have read in some online documentation refer to?
Can anybody tell me what is the maximum capacity for readtnas ultra 2?
Thansk for help
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    There are only disks up to 3TB in capacity on the compatibility list at this time: http://kb.netgear.com/app/answers/detail/a_id/20641
    However some users have found 4TB disks work fine for them.
    In the future even higher capacity drives will be released. Currently there are no known reasons why higher capacity drives still would be incompatible but it's possible they my not be compatible.
    The ReadyNAS Ultra 2 uses the EXT4 filesystem which theoretically supports volume sizes much higher than you will ever have in an Ultra 2 unit.
    With two 4TB disks using RAID-1 you would have a volume of about 3.6TB which could theoretically be expanded to about 11.6TB without doing a factory reset.
    Do note that a new model the ReadyNAS RN312 has been released. This has a newer faster CPU, double the RAM, runs a newer OS and has 4TB disks on its compatibility list. You may wish to consider buying one of these if it fits within your budget.
  • Thanks for the helpful reply.
    The only reason I want to buy an Ultra 2 is that there is a nice discount in my favorite online shop.
    I will pay 355 Euro (465 $) for an Ultra 2 and 2x2TB (seagate) hard drives.
    The reason I asked the question was that I wondered if it would be possible for me to expand the capacity in the future for possible needs.
ProSupport for Business
