DJOROD
Jan 30, 2019Aspirant
Maximum Storage by Disk and Total Unit Capacity
Hi,
I am a proud owner of a RNDU4000 (ReadyNAS Ultra 4 [X-RAID2]) that I've been using, going on 10 years now. I'm currently running RAIDar Utility Version 6.4.0 and Firmware/RAIDiator 4.2.31 with three disks (two 3TB and one 2TB) and 1024 MB of DDR2 RAM. I am wanting to upgrade each drive to 4TB (or possibly 6TB) but given this NAS's age, I don't know if it would support it. Can someone help?
Many Thanks in Advance!
DJOROD
There are two expansion limits in the 4.2 firmware
- a volume can't expand over 16 TiB
- a volume can't expand more than 8 TiB from it's initial size.
So in the case of a 4-bay ultra, the first limit means that you can expand to 4x4 TB (12 TB volume) or even 4x5TB (15 TB volume). 4x6TB exceeds the 16 TiB ceiling, but 3x6TB+4TB would work.
The second limit might also apply, and if it does you'll need to do a factory reset with all disks in place.
You can convert your NAS to run OS 6 - which doesn't have these expansion limits. That process isn't supported by Netgear, but many have done it. It does require a factory reset, but you are facing that possibility already. In addition to eliminating the expansion limits, you'd also get new features - including support for SMB 3.0, which is helpful since Microsoft is deprecating the SMB 1.0 protocol that your ultra uses.
- DJORODAspirant
Hi Stephanie,
Thanks for your prompt reply on this. Converting my NAS to run OS 6 sounds very enticing but I fear that in doing so, this procedure could also "brick" the appliance. Would I be at risk of this?
I haven't seen any posts from Ultra owners reporting a bricked NAS when doing the conversion. There are a couple of OS 4.2.x NAS models that use 32 bit processors, and they can be bricked - but the Ultra is a 64 bit platform.
There are also a couple of folks who found that the upgrade resulted in the NAS no longer knowing it's serial number. That creates issues connecting to ReadyCloud. Netgear mods here (for example JohnCM_S ) have solved that problem for a couple of folks.
As I said, it is not supported by Netgear - and you won't be able to get paid Netgear support if you switch. But overall, people doing this conversion have reported success.
- Sep 02, 2016Retired_Member
