sirgeek
May 11, 2013Follower
Memory Upgrade For ReadyNAS 100-104
I hope this is the right place to post this, I APOLOGIZE IN ADVANCE IF IT IS NOT. I just bought a ReadyNAS 104 and I want to increase the memory, but I haven't been able to open the case to do so. ...
May 11, 2013Guru - Experienced User
I'm not certain about the RN1xx, but the other ReadyNAS ARM systems have the memory soldered on. So I am thinking it is quite unlikely that you can add RAM.
If it is possible, it would void the warranty.
