lucifor
Aug 18, 2012Aspirant
MGE (Eaton) Ellipse 600 USBS
Hello
I have one of this UPS, but i haven´t the USB Connector. This Connector ist a standard RJ-45 Network Connector :) Can anybody tell me the PIN-COnnect of the USB Connector (tx/rx/grnd and V+)?
Greetz
Lucifor
Greetz
Lucifor
- luciforAspirantThanks so long
i found a other one also on a Francais Site
USB RJ45
1 ----------------- 1
2 ----------------- 7
3 ----------------- 8
4 ----------------- 5
shield ------------- 4
Look like the same, i will try and post again. But i try not on the nas :) a old Notebook have to be the first one :)
Edit: MGE/Eaton not response an eMail :( i will try. - StephenBGuru - Experienced UserThe pinout hits I am googling are mostly for a 10P10C (RJ50).
I did find one pinout here: http://www.nas-forum.com/forum/topic/19 ... e__st__140Bonjour,
j'ai teste les correspondances sur le cable Rj45 / USB de mon MGE Elippse avec un testeur de cables....
RJ45 USB
1 -> 1
2
3
4 -> 4
5
6
7 -> 2
8 -> 3
Voila!
J'espere avoir pu t'aider
Serpinh - luciforAspirantThe one from APC should work also. Anyone have the Pin-Out for this Cable?
The Prices for a buyed Cable are to many expensive. For the cost of this Cable u can get a new UPS :// - StephenBGuru - Experienced UserSome APC apparently use RJ45 also (http://www.apc.com/resource/include/tec ... sku=AP9827).
- luciforAspirantHi
The UPS have an RJ-45 Connector to USB, also RJ-45 <-> USB Type A (flat). If you buy a new one ther are two Calbles in the Package one RJ-45 <-> RS-232 and one RJ-45 <-> USB, both Cables are with no logik. It looks like the same as from APC, but APC use a RJ-50 <-> USB with other pins. - StephenBGuru - Experienced User
You can see a picture here: http://www.fusionps.com.au/products/ups ... e_Max.htmlPapaBear wrote: What type of socket does it have. I finally managed to find specs and it says for management it has USB and RS-232. It just does not tell which USB socket it has, square or flat. Flat is normally for the host (the ones on the ReadyNAS) and the square is normally for the attached device (as found on hard drives, etc). If it is the square socket then a standard USB cable should work, if the flat then you need a USB cable with two flat connectors.
It appears to filter a single ethernet connection (the top two connectors on the right), and also have an additional RJ45 connector for the control port. I believe there are two custom cables available for the control port, one which adapts it to RS-232, the other adapts it to USB. Some APC UPS also do it this way. You can find a cable here: http://www.thenerds.net/STARTECHCOM.Sta ... ml#details - though I don't know for sure if that will work with the Ellipse, or just the APC. - PapaBear1ApprenticeWhat type of socket does it have. I finally managed to find specs and it says for management it has USB and RS-232. It just does not tell which USB socket it has, square or flat. Flat is normally for the host (the ones on the ReadyNAS) and the square is normally for the attached device (as found on hard drives, etc). If it is the square socket then a standard USB cable should work, if the flat then you need a USB cable with two flat connectors.
