Blabert
Dec 26, 2011Aspirant
Migrate broken Duo data to Ultra 2 (or just make it work aga
Hello, My Duo seam to have seezed - at least it is not booting up. I have not yet tried to factory reset the unit yet because it will erase the data. I am willing to buy a ne Ultra 2 cabinet, b...
PapaBear1
Dec 26, 2011Apprentice
What are the symptoms of the Duo. When it is off, and you press the power button, what actions occur? Do any lights come on or does it try to start booting and just stops. Do you get any lights flashing in a repetitive manner?
