Blabert
Dec 26, 2011Aspirant
Migrate broken Duo data to Ultra 2 (or just make it work aga
Hello, My Duo seam to have seezed - at least it is not booting up. I have not yet tried to factory reset the unit yet because it will erase the data. I am willing to buy a ne Ultra 2 cabinet, b...
mdgm-ntgr
Dec 27, 2011NETGEAR Employee Retired
Blabert wrote:
I will open a case.
Good.
Blabert wrote:
don't they indicate that the disk is present when just shining steady?
Yes.
Blabert wrote:
What about my idea to do the factory reset with a new disk? Would that mean that the cabinet will not recognize the old disks any longer?
If you power down, remove all disks (label order) and insert a new disk and do a factory reset the new disk will be wiped and firmware installed on the disk. If this works fine, this indicates that the flash is fine.
If you want to go back to the old disks you would need to power down, remove all disks and put the old disks back in the same order as before.
