kinematic
Oct 18, 2013Aspirant
Migrate discs from RNDP400U to RN104
My RNDP400U suffered a fatal fall and is out of commission. I ordered a RN104 to replace it since the RNDP400U is discontinued. I have installed the 4 WD green 3 TB drives from the old unit (I know th...
TeknoJnky
Oct 18, 2013Hero
If you are confident of your backed up data, you should be able to do a boot menu factory default which will wipe all data on those disks and install the new os 6 and filesystem.
if you mean you want to retain the data on the disks while using them on the RN104, it is not possible due to the new OS and filesystem (btrs vs the old ext4).
