kinematic
Oct 18, 2013Aspirant
Migrate discs from RNDP400U to RN104
My RNDP400U suffered a fatal fall and is out of commission. I ordered a RN104 to replace it since the RNDP400U is discontinued. I have installed the 4 WD green 3 TB drives from the old unit (I know th...
kinematic
thank you very much for your response. the backup data is on another NAS so I have redundant backup data but I will restore as much as I can to my local drives before I wipe the others.
could you explain how to do a boot menu factory default? currently radar cannot see this NAS as it does not completely boot up.
also, in you opinion, should I opt for the 314 or is the 104 adequate as a file server for a small business? the RNDP400U seemed to work just fine for our needs.
thank you in advance
