kinematic
Oct 18, 2013Aspirant
Migrate discs from RNDP400U to RN104
My RNDP400U suffered a fatal fall and is out of commission. I ordered a RN104 to replace it since the RNDP400U is discontinued. I have installed the 4 WD green 3 TB drives from the old unit (I know th...
kinematic
Oct 19, 2013Aspirant
thank you for your help and opinion. my current drives should work once they are wiped correct?
