kinematic
Oct 18, 2013Aspirant
Migrate discs from RNDP400U to RN104
My RNDP400U suffered a fatal fall and is out of commission. I ordered a RN104 to replace it since the RNDP400U is discontinued. I have installed the 4 WD green 3 TB drives from the old unit (I know th...
Oct 19, 2013Guru - Experienced User
They likely will work, but if there is an issue, Netgear will deny support if you are using disks off the HCL.
kinematic wrote: ...my current drives should work once they are wiped correct?
