kinematic
Oct 18, 2013Aspirant
Migrate discs from RNDP400U to RN104
My RNDP400U suffered a fatal fall and is out of commission. I ordered a RN104 to replace it since the RNDP400U is discontinued. I have installed the 4 WD green 3 TB drives from the old unit (I know th...
mdgm-ntgr
Oct 21, 2013NETGEAR Employee Retired
You may wish to run idle3-tools or WDIDLE3 on the disks if you haven't already. Though the disks would already have very high load cycle counts if you haven't.
Make sure you keep a regularly update backup. So if something does to wrong you can restore from backup if needed.
Also, if support does refuse to help with a problem you can still seek help here.
