bofh666
Feb 29, 2020Aspirant
Migrate disks between architecture (RN214 to RR2304)
Hi, I’d like to upgrade from an ARM-based RN214 to an Intel-based RR2304. I’ve seen a few posts saying you can just move the disks, but also some (much older, mostly) which say you can’t move betwe...
- Feb 29, 2020
Hi bofh666,
Welcome to the Community!
It is possible for you to move the disks from the RN214 to the RR2304 but since you are migrating from an ARM-based unit to an Intel-based unit, the apps installed may not work. It will be best if you uninstall first the apps then install the x86 version of the app after the migration.
It is also a best practice to do a full backup first of your data before migrating the disks.
JohnCM_S
Feb 29, 2020NETGEAR Employee Retired
Hi bofh666,
