Aaronius
Aug 17, 2019Aspirant
Migrate from RN104 to higher spec model, advice please
Hi all, I need a little advice concerning my current ReadyNAS 104. It has been reliable and consistent from day 1 and I have no complaints other than speed, but I think the speed question is...
Aaronius
Hi Sandshark,
Thanks for your reply. The 6-bay makes sense, I will look at what (if) is possible in terms of budget. the 10 gigabit sounds nice. :)
Can you tell me - is there a way to migrate the hard drives in such a proposal? I mean take the drives from my current 104 to the next system? Or must it be a data transfer?
Before buying new equipment, would it be better to use a RAID 10? If so, can the system be converted from my current RAID 5 (x-raid). Without erasing and starting from scratch?
I have 4x3tb WD Red drives. And currently have approx 4.5TB data.
Sandshark
Aug 17, 2019Sensei
Yep, you can take your current drives over to the new system. If you will be going from an ARM to Intel based system (which I recommend you do), you should uninstall any apps you have first. It's also a good idea to have the new NAS running the same version of the firmware as the old one, but not essential. To make sure that's the case, you'd have to temporarily install a spare drive in the new NAS to verify/update as necessary.
