joso73
Nov 14, 2013Follower
Migrate from Ultra 4 to 314
I have a Ultra 4 and I'm thinking about buying a 314. Can I move the harddrives from the Ultra 4 to the 314 and the data will be intact or do I have to backup the data first and restore it after I hav...
confidentjohn
Jan 10, 2014Aspirant
Hi
Im in a similar position. I have just upgraded from an ultra to the 316
I want to copy my files over but am unsure of the best way.
Is it possible to directly connect the two using the second Ethernet?
Can I copy on a folder basis?
Currently I am copying data via a laptop which is the slowest means going but I note that one copied all files will work and be in the place I want.
Cheers
John
Cheers
John
