funglenn
Dec 21, 2016Luminary
mirgrate Array from ReadyNas 204 to a Readynas 516?
I can I mirgrate my Array from a ReadyNas 204 to a Readynas 516? I realie one is ARM and the latter is x86. However they are both running 6.6.0 I migrated my array from a 104 to my 204, so i ...
Dec 21, 2016Guru - Experienced User
You can, but some apps won't work afterwards. So it's best to simply uninstall all the apps, and then reinstall them afterwards.
It's great that Netgear does that migration - and not simple, since as you say the platforms are completely different.
