dmahon1
Dec 07, 2012Aspirant
Mirrored NAS boxes
Is it possible to have mirrored readynasses? Eg - have two addresses A and B. Each has a NAS. A and B are linked by the internet, although the link is not amazingly speedy hence the two NAS.each en...
Jan 03, 2013Guru - Experienced User
You could set up a brother-backup share on each site, and backup to folders within that.
Though with the duo v1 you won't be able to create a secure connection (since rsync over ssh isn't a duo v1 feature). You could possibly create a vpn tunnel between your two locations if you added in vpn routers. Or use viewtopic.php?f=47&t=29688 - which will be slow, but may be good enough.
Also, the initial backup would be faster if you put co-located the two NAS and did an NFS backup between them (then editing to rsync and running again).
How fast are your internet uplinks?
