cathcam
Mar 03, 2015Guide
Mismatched drive replacement
I have ReadyNas NVX Pioneer Edition, 4x 2TB Seagate ST32000542AS, its been running flawlessly for 4+ years. It's running the latest level 4.2.27, running as RAID Level X-RAID2, 4 disks When I reboo...
vandermerwe
Mar 04, 2015Master
That is a very high count and the drive must be replaced.
First check that the drive cannot be replaced under the 3 year warranty:
http://support.seagate.com/customer/en- ... dation.jsp
If it can't, I would suggest buying either a seagate nas drive:
http://www.amazon.com/Seagate-Cache-3-5 ... eagate+2tb
or a wd red drive:
http://www.amazon.com/Red-2TB-NAS-Hard- ... wd+red+2tb
You should have a backup of the data on the nas.
or a wd red drive:
