cathcam
Mar 03, 2015Guide
Mismatched drive replacement
I have ReadyNas NVX Pioneer Edition, 4x 2TB Seagate ST32000542AS, its been running flawlessly for 4+ years. It's running the latest level 4.2.27, running as RAID Level X-RAID2, 4 disks When I reboo...
Mar 04, 2015Guru - Experienced User
No.
cathcam wrote: I had expected to buy a drive, my real question was on compatibility between drives. Does it matter if the ReadyNas has 3x 32mb buffer, 512 block drives and 1x 64Mb, 4k block drive?
You do need to make sure the replacement is at least 2 TB.
