robturpin
Jul 30, 2016Apprentice
Missing Folders
For the second time now, multiple folders have mysteriously disappeared from within the Videos directory of my ReadyNAS! This happened once when I first purchased it (used), and now again after I com...
- Jul 30, 2016
robturpin wrote:
"The /MIR switch tells Robocopy you want to mirror the two folders, copying all folders (even empty ones) from the source directory and purging folders from the destination if they no longer exist on the source."
Yes, that is exactly what /MIR does. It syncs the destination to the source - including deleting any files in the destination folder that no long exist in the source.folder.
robturpin wrote:
I'm going to assume (save some kind hearted generous Windows/Linux guru out there wishes to display pity upon my stupidity by helping me recover them through advanced magical wizardry), that my files are completely gone from the NAS.
They are gone from the NAS. There are some tools that could potentially recovery them, but odds are not good.
robturpin
I've been retracing my recent steps, and I might have found the cause of my particular issue. I've recently learned of the Windows command "Robocopy", which is a very efficient, powerful and yes even dangerous file management tool.
I initially noted that the "/MIR" switch would mirror the complete directory structure of the source onto the destination. In re-researching the details of this command, I found these chilling details:
Oh, and if this is indeed the reason for both of my incidents, then I sincerely apologize for thinking and speaking ill against Netgear and their ReadyNAS devices and software.
Jul 30, 2016Guru - Experienced User
- robturpinAug 05, 2016Apprentice
Thanks StephenB.
Yes, it's confirmed, as I've now been running strong for an entire week with zero (0) issues on my ReadyNAS Ultra 6.
RoboCopy = BAD (or at least VERY dangerous...)!!!
RichCopy 4.0 = MUCH better!!
- StephenBAug 06, 2016Guru - Experienced User
Robocopy isn't BAD (or dangerous). But you do need to know what the options do before you use them.
Richcopy has a similar mode to /mir, which it calls "purge". Personally I find it that name more confusing than "mirror".
