rit1
Aug 05, 2014Aspirant
More feedback on backup issues of 6.X
I now own 2 RN104 devices - so Netgear must be doing something right from my point of view, even if its just the current low cost of the device in the UK. My configuration is now a primary RN104 (4...
Aug 05, 2014Guru - Experienced User
-The path stuff can be confusing, and the answer often depends on the protocol. In the case of RSYNC, the remote path is generally just the share name, with no slashes.
-I can see and change the paths on my existing backup jobs. Though I am running 6.1.9 RC at the moment, I believe this was also the case with 6.1.8
-"Remove Deleted files on Source" means what you think it does. Files that were deleted on the source are deleted on the destination as part of the backup jobs. The wording is perhaps confusing, but I am not coming up with a succinct wording that is any better. "Remove files deleted in the source from the destination" seems a bit too wordy, and might not be any clearer.
