mhellstrand
Jan 11, 2013Tutor
Move disks after Hardware failure, possible?
Hi I have had a hardware failure on my Ready nas duo v.2. And it will probably never wake up anymore. My question: Is it possible to remove the disks (currently 2 mirrored disks) from the broken d...
mdgm-ntgr
Jan 11, 2013NETGEAR Employee Retired
What symptoms suggest to you that the Duo v2 hardware has failed and won't wake up?
What happens when you press the power button to try to turn it on? Does it show up in RAIDar?
Were you using the power off/on timer?
What version of RAIDiator were you running?
Please read this and confirm if you have a Duo v1 or a Duo v2: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
It is important. You cannot migrate from a v1 to a v2 or vice versa.
