doubleos
Oct 24, 2018Guide
Moving System from Readynas 516 to 716
I'm considering buying a 716 chassis and moving my 516 disks to the new chassis. As I understand it there should not be any problem moving the volumes as long as I move all of the disks for the volu...
Oct 24, 2018Guru - Experienced User
The system is on the disks, so migrating the disks will move both.
If the RN716 is running newer firmware than the RN516, then the new NAS will upgrade the system on the disks. If it is older, then the NAS will update it's flash from the system on the disks. If you want to avoid this step you could install a scratch disk on the RN716 and then manually install the same firmware you are running on the RN516.
- doubleosOct 24, 2018Guide
Thank you Stephen! So, if I am understanding you correctly. If the firmware on the 716 is newer, I could replace the system hard disk with a scratch one, manually install the earlier firmware and then replace the system hard disk with the one I have on the 516. If the firmware is the same version or earlier, I could just replace the system hard disk and the firmware flash would automatically get upgraded if needed. Is this correct?
Just to make sure. You mentioned that migrating the disks will move the system. Are you saying that the system is copied to the nas volume(s) from the system disk and therefore my modifications to the OS (adding virtual box for instance) and apps would be ported by just moving the volumes?
- mdgmOct 25, 2018Virtuoso
The RN716X would likely be a second hand purchase (units sold new for more than the RN626X sells for now so buying the RN716X at new prices would make little sense).
There’s no warranty or NETGEAR support for second hand purchases.
Firmware mismatches are mainly likely to be an issue if the replacement unit comes with significantly older firmware than the old unit. Newer firmware on the replacement unit isn’t a problem.
The OS is installed on the disks and all your config and data is either on the OS partition or one/more data volumes. So it will move with the disks.
If you don’t want to rework your modifications for a different kernel (there is info on the community for getting VirtualBox working on newer versions of ReadyNASOS) I could understand wanting to make sure the firmware matches exactly, but you would be missing out on lots of security and other fixes staying on such old firmware. There’s been a major upgrade to the core OS and multiple major kernel upgrades since 6.1
