Wolfsvudo
Aug 11, 2024Follower
MS2000 Trying to Access
MS2000 SN: 27829C7D019F3 MAC: 0026F28641FD Hello, This product belonged to my now deceased Father. I have access to his Netgear account and the physical device. I am trying to retri...
saudade
Aug 11, 2024Apprentice
My condolences for your loss.
I'd start here and get the user manual.
https://www.netgear.com/support/product/ms2000/#docs
Assuming it powers up and is connected to your home network, and the disks function properly, go to the Access Your Stora section under installation section. You may need the username and password that was used to initially set it up.
Since I don't have this unit. I can't suggest anything more. Hopefully, you'll get your content off.
Aug 11, 2024Guru - Experienced User
Wolfsvudo - Sorry to hear about your father.
I don't have this unit either, and Netgear dropped the cloud service for it back in 2020.
If you can't access the data from the system, it is possible to use data recovery software - connecting the disk(s) in the stora to a Windows PC.
My understanding is that the Stora used the XFS file system. There are a couple of specific RAID recovery packages suggested here:
Note Windows doesn't support this file system, so it won't mount the disks. You'd need to use the recovery software. Or find someone with the skills to manually mount the volume in a linux PC.
- SandsharkAug 12, 2024Sensei
My understanding is that if the Stora was set up while the mystora.com website was still up and you know the user name and password, you can still access the data via the local network. It has the same TLS version issue as older ReadyNAS, and I've also seen reverences that it needs flash player (which is not available for current versions of windows. So, it's best if you also have the PC from which it was accessed.
But you may also want to see this: Stora_Harddrive_Recovery .
