carpii
Aug 26, 2012Tutor
Multiple failing Seagate Barracuda ST32000542AS
I bought 3 ReadyNAS (over the course of 5 months), and populated them all with identical Seagate Barracuda's They are the Barracuda LP ST32000542AS model, on the HCL and I chose these because there w...
carpii
Aug 29, 2012Tutor
StephenB wrote: You can use 3 TB drives with your 2 TB drives if you are using XRAID2 and have firmware of 4.2.16 or later.
Thats great, Thanks Stephen
Im using 4.2.19 and XRAID2 :P
- Aug 17, 2011Retired_Member
