carpii
Aug 26, 2012Tutor
Multiple failing Seagate Barracuda ST32000542AS
I bought 3 ReadyNAS (over the course of 5 months), and populated them all with identical Seagate Barracuda's They are the Barracuda LP ST32000542AS model, on the HCL and I chose these because there w...
PapaBear1
Aug 29, 2012Apprentice
Be sure to back up all your data before you start and replace the drives one at a time. After you have replaced the second drive, it will take at least one and maybe several reboots before the vertical expansion starts and it will take much longer than the resync.
I when through this when I replace two 1TB drives with two 3TB drives on both of my NVXs.
- Aug 17, 2011Retired_Member
