carpii
Aug 26, 2012Tutor
Multiple failing Seagate Barracuda ST32000542AS
I bought 3 ReadyNAS (over the course of 5 months), and populated them all with identical Seagate Barracuda's They are the Barracuda LP ST32000542AS model, on the HCL and I chose these because there w...
carpii
Aug 29, 2012Tutor
PapaBear wrote: Be sure to back up all your data before you start and replace the drives one at a time. After you have replaced the second drive, it will take at least one and maybe several reboots before the vertical expansion starts and it will take much longer than the resync.
I when through this when I replace two 1TB drives with two 3TB drives on both of my NVXs.
The failing NAS is actually just a backup NAS for my 1st one. I rsync it across each night
I havent done a volume expansion before, so thanks for the tip!
- Aug 17, 2011Retired_Member
