carpii
Aug 26, 2012Tutor
Multiple failing Seagate Barracuda ST32000542AS
I bought 3 ReadyNAS (over the course of 5 months), and populated them all with identical Seagate Barracuda's They are the Barracuda LP ST32000542AS model, on the HCL and I chose these because there w...
PapaBear1
Aug 29, 2012Apprentice
Sounds like my set up. Two NVX units, one is the primary and mapped in Windows, the other is the nightly rsync back up target of the first.
In that case I would go ahead and update the drives in the backup. When I do any updates, I do it on the backup (NVX Pioneer) before I do it on the primary (NVX BE) a week later.
- Aug 17, 2011Retired_Member
