merenon
Aug 04, 2011Aspirant
Multiroom Audio Streaming with ReadyNAS
Hi there, I consider buying a Netgear RND2110-100ISS. One of my major wanted feature is a multiroom audio streaming possibility. But some background infos beforehand: We have a living room w...
timvd
Aug 06, 2011Aspirant
This is perfectley doable with the squeezebox server software on the readynas. Just install the squeezebox emulator called 'squeezeplay' on all your computers, and you can play music from the readynas server software. you can then sync the connected clients, even the emulated ones, so all players are exactly playing the same thing.
Later you can integrate the Squeezebox devices in your setup, if you like (and which i recommend, because i find the squeezeboxes excellent!) But on the other hand, if you don't need hardware squeezeboxes, this is a completely free (and open source) solution!
It does take some time to set up the squeezebox server, but it's quite user friendly, and really easy to use.
Let me know if you need more info
