Buzz1
Aug 30, 2014Aspirant
My Experience with NVX BE and 4x WD60EFRX 6TB Drives
All, I recently decided to upgrade my trusty NVX Business Edition ReadyNAS from 4x 1TB drives to 4x 6TB drives. After reading many posts on these forums I quickly realised that 6TB drives were not ...
Buzz1
Sep 01, 2014Aspirant
@mdgm - thanks for your help.
Taking your comment and the advice given by StephenB, the default available volume size after overheads and snapshot allocation did just creep above the 16TiB limit.
I have created a volume within Frontview of 16000000MB which appears to have worked (currently resyncing). Assuming the ReadyNAS definition of MB is MiB then I think this is the maximum volume size I can create.
I guess I am lucky in that I am only loosing a few 100GBs as the available space after overheads is around the 16TB limit using 4x 6TB drives.
Thanks for your help.
Buzz.
Buzz.
