JackDC1
Jul 04, 2014Aspirant
My Readynas N+ v.2 has a disc failure, which one?
One of my hardrive has a disc failure on my Readynas Nv+ v.2. The raid type is X-Raid 2. It is still redundant. The volume is orange. In the info tab it shows all disc are okay in the status. I realy ...
Jul 04, 2014Guru - Experienced User
It doesn't look to like any drives have failed - and that on March 27th-28th it successfully recovered from whatever happened on the 26th.
You could contact support (support.netgear.com, use email) to confirm. Also, you should look at the SMART stats for all the drives.
