JackDC1
Jul 04, 2014Aspirant
My Readynas N+ v.2 has a disc failure, which one?
One of my hardrive has a disc failure on my Readynas Nv+ v.2. The raid type is X-Raid 2. It is still redundant. The volume is orange. In the info tab it shows all disc are okay in the status. I realy ...
Jul 05, 2014Guru - Experienced User
Page 72 of your software manual. http://www.downloads.netgear.com/files/ ... 20NV+%20V2)/RAIDiator%205.3%20SW%20Manual_5Sep12.pdf
JackDC wrote: Thanks for the reply I have contacted Nethgear. Where do I find the SMART stats?
