heywheelie
Apr 10, 2019Tutor
My readyNAS RN212 not detecting latest firmware
When I'm logged into Admin on my RN212 which is currently running firmware 6.9.5 and click on "Check for Updates" the popup always says "Your system is currently running the latest
firmware. Your...
- Apr 10, 2019Hey.
It's normal. Same thing here.
NETGRAR always release manual install first and then later release it to their update servers. It's so that they can assess how it goes first before releasing to all users.
I always wait till it's available on the update servers.
Retired_Member
Apr 11, 2019Hi heywheelie , another reason could have been, that you had chosen to stick with "Long-term support". There are three upgrade modes: (1) Long-term (2) Stable and (3) Beta, which you can choose on the admin/systems/settings page. Long-term support currently would not upgrade to 6.10.
Kind regards
heywheelie
Apr 11, 2019Tutor
t seems you are correct Roland. I had forgotten about that setting.
