broad01
Feb 05, 2020Tutor
NAS 104 Locked Up
NAS has locked up. Can not access. Can not even ping.
See attached photo of the display.
Will not soft shutdown using power button.
Any ideas?
- Marc_VNETGEAR Employee Retired
Can you still access the Boot menu? Were you able to check the status of the NAS on RAIDar?
You may want to try booting it on Ready only mode. Kindly check if you can download the logs as well.
Many thanks!
Regards
- broad01Tutor
Hi Mark
As I said in my post
"Can not access. Can not even ping."
Not even with RAIDar. RAIDar says no devices found.
What do you make of the message on the display? What does this tell you what problem is?
I think the only thing I can do is unplug it. How much risk is there of data loss if I do this? Surly the display message will tell you the issue and if a hard reboot will cause data loss?
Thanks
Adam
- SandsharkSensei
A hard reboot in this case should not cause a volume issue. Buit, you may already have a volume issue that will only become apparent after a re-boot. Re-booting in read-only mode may be prudent.
Frankly, though, what choice do you have? With no GUI or SSH access, you have no way to do anything else.
- broad01Tutor
So i power cycled the NAS. It came back and all looked OK. A few days later a new message appeared,
"btrfs_search_forward+2ac"
Again NAS totally locked up. power cycled again. Now NAS shows a popup which says "No volume exists" with a warning message "Remove inactive volumes to use the disk. Disk #1,2,3,4."!!!!!!!!!!!!
Lookes like I have lost all my data again.... Anyway to recover?
logs attached.
This is the third time with a Netgear NAS.
- broad01Tutor
Hi
I have tried re-booting into read only mode. Still no volume.
I want to SSH into the unit to check if the data is still there and try a re-mount. I get a connection refused. i went to settings in admin and see under services that SSH is not selcted. I am unable to enable SSH, when I try it says "cannot start service without a volume"!! Is there any way I get enable SSH or get in bypassing the admin setup? How about the tech mode in the boot menu?
Thanks
Adam
