123vern
Feb 17, 2023Aspirant
Nas 2100 reset problem
Hi before I go to the shed and get my sledge hammer I thought I would reach out to people far more knowledgeable than me. I have been for the past 12 hrs trying to reset my new to me 2100 series nas...
123vern
Hi again I have pressed the off button and this has com up that isn’t my net mine is 192.168.1.xx
123vern
Press admin and it says not accessible from this computer?
Cheers
- StephenBFeb 17, 2023Guru - Experienced User
Well, of course it won't be if the IP address the NAS is using isn't on your subnet.
If RAIDar isn't showing the disks resyncing, then try doing an OS reinstall (not a factory default) from the front panel. Instructions are on pages 12-13 here:
- 123vernFeb 17, 2023AspirantHi and thanks I can get into it now but when I press admin page the browser I get security can’t access site download brave and still no good any hints
Thx- StephenBFeb 17, 2023Guru - Experienced User
ThxAre you seeing SSL version or cipher mismatch?
If so, there is quite a bit of info here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Workaround-for-ERR-SSL-VERSION-OR-CIPHER-MISMATCH-problem-for/m-p/2198243
The short answer:
Use one of these for initial access
- IE
- Edge in IE mode
- FireFox 94.0.2
- Current Firefox with TLS 1.0 allowed (see end of linked in thread)
Then install this add-on to add support for TLS 1.2 to the NAS:
