studdsit
Jan 12, 2022Aspirant
NAS getting antivirus update error
Dear All Can you help me with this problem : System: Antivirus scanner definition file update failed due to download failure. Check your Internet connection. My NAS model is ReadyNAS 4312...
studdsit
Thanks for your reply
When I try to update OS from 6.10.1 then it says :
"Your system is currently running the latest firmware. Your system does not need a firmware update"
I have attached screenshot as well
Also I followed this solution :
but after this on antivirus I am getting this error :
"Updating virus library. Refresh to update status"
Screenshot attached along with
Sandshark - request your help
Jan 13, 2022Guru - Experienced User
studdsit wrote:When I try to update OS from 6.10.1 then it says :
Check the update setting (system->settings->update in the web ui).
I am thinking yours might be set to "long term stable".
Either change it to "stable" and try again, or manually install the firmware from https://kb.netgear.com/000064345/ReadyNAS-OS-6-Software-Version-6-10-6
