ShadowStorm
Feb 06, 2017Aspirant
Nas is not booking after latest firmware update
After the firmware update it was fine up untill today were it failed to boot, the power light is just flashing (Im sure its just failing to boot) I have tried to reinstall the OS but his did not ...
- Feb 06, 2017
Then you didn't follow the USB Boot Recovery instructions. In any case this doesn't sound like an issue that USB Boot Recovery is likely to fix.
Have you been getting any SMART errors on your disks?
Have you tried powering down, removing your disks, hooking them up to your PC and testing them e.g. using SeaTools for SeaGate disks and WD Data LifeGuard Diagnostics for WD disks?
mdgm-ntgr
Feb 06, 2017NETGEAR Employee Retired
- ShadowStormFeb 06, 2017Aspirant
On one of the disks but a have ordered a repalcement for it the other disk is fine
