haka1311
Mar 03, 2019Aspirant
NAS Neatgear network letter
I do have a NAS Netgear READYNAS NV RND4000 but since i have a new desktop i can`t connect a drive letter to my NAS.
I do see the NAS in Network connections and i multi media by these way i can connect to the NAS as also by the IP-address.
What i like to do is connect a drive letter tot he NAS.
By my second NAS this is not a problem.
Can some one help me out. Thanks in advance.
haka1311 wrote:
yes i can ping the adress
and used the line net use t: \\192.168.0.220\C /user:admin my password
Try rebooting the PC, and then executing the two commands again:
net use * /delete
net use t: \\192.168.0.220\C /user:admin nas-admin-password
The first step is to go into "turn windows features on or off" in the PC, and make sure that the SMB 1.0 client is installed. Have you done that?
Also, what firmware are you running in the NV+?
- haka1311Aspirant
Stephen SMB1 .0 was turn off, but still have the same problem can not connect to ip adres of find a drive letter.
i do use firmware RAIDiator 4.2.31
hope you can help me further.
thanks
- HopchenProdigy
Did you also enable SMBv1 in Windows settings? These older NAS units are, to my knowledge, only capable of SMBv1 so you must that.
